Date/Time: Wed, 30 Oct 2024 22:55:56 +0000
MenuCustomizations.xml and UTF-8
View Count: 2234
[2014-07-19 13:11:39] |
ganz - Posts: 1048 |
SC Support Looks like it isn't working for UTF-8 fonts in terms of using the cyrillic charset but chartbook's names are correct in cyrillic. Does it support UTF-8 or what should I do to get it working? thnx. |
[2014-07-19 18:06:29] |
We should be able to get this working by using 16-bit characters. Right now only 8-bit characters are supported. We will try to support 16-bit.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-19 18:07:07
