Date/Time: Tue, 26 Nov 2024 21:34:24 +0000
Set blocks of more than 2 sessions during the day and include session high and low.
View Count: 294
[2023-10-17 23:50:29] |
Jimmyz83 - Posts: 51 |
If you look at the attached pic you will see blocks of individual sessions I want to follow. not just the time block but also the high and low of the individual session. Currently the chart settings only allows for 2 sessions, day and evening. I can not find a study that does this, please help to set the session blocks automatically. The blocks on the chart attached are just rectangles I had to manually add. thanks for the help.
Screenshot 2023-10-17 184445.png / V - Attached On 2023-10-17 23:49:47 UTC - Size: 9.27 KB - 73 views |
[2023-10-18 14:33:46] |
John - SC Support - Posts: 36308 |
You can use multiple copies of the "Time Range Highlight" study to color the background different colors for the different time periods you want to view. Refer to the following: Time Range Highlight For the High and Low, use the "High Low for Time Period" study. Refer to the following: High/Low for Time Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
