Date/Time: Tue, 26 Nov 2024 20:32:03 +0000
Suggestion.: Allow to set opacity for the
View Count: 337
[2023-10-17 20:10:16]
User408639 - Posts: 69
Moin Moin.
Suggestion.: How about allowing to set the opacity-value in 1-increments from 0 to 255 for the "Opaque Background"-option of the text-tool.
Right now it is a checkbox ↔ either 0 or 255, but no values inbetween. (Please see the screenshot.)
This way, one could be deciding to have a tradeoff between being able to see the tools/drawings in the background, and the text.
_Tschüß,
__Michael.
imageSuggestion.˸ Allow to set opacity in 1-increments from 0 to.png / V - Attached On 2023-10-17 20:09:47 UTC - Size: 118.78 KB - 85 views
[2023-10-20 14:46:45]
Sierra_Chart Engineering - Posts: 17184
The Windows operating system has no support for this.
[2023-10-22 10:46:14]
Moin Moin.
In Excel (on Windows 10/11) You can use semi-transparent rectangles. (Please see "In Excel You can use semi-transparent rectangles....png" ).
_Tschüß,
__Michael.
imageIn Excel You can use semi-transparent rectangles....png / V - Attached On 2023-10-22 10:46:07 UTC - Size: 250.72 KB - 87 views
