Date/Time: Sun, 24 Nov 2024 20:18:28 +0000
SIERRA VS JIGSAW DOM
View Count: 1735
[2023-10-17 15:59:09] |
tradewerx - Posts: 6 |
Hello, i have switched from jigsaw to sierra. i have noticed a small but considerable lag in sierra dom. i have changed the chart update settings to match jigsaw (50ms). i have both sysstems running on the same data feed. i also raised all of the other chart update settings to take the load off. any suggestions? here is a video of the 2 running together with the video slowed down 10x
jigsaw.vs.sierra.mp4 - Attached On 2023-10-17 15:58:54 UTC - Size: 3.91 MB - 565 views |
[2023-10-17 16:13:54] |
Sierra_Chart Engineering - Posts: 17161 |
Refer to: Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-26 11:51:13] |
User463681 - Posts: 1 |
Hello tradewerx, I'm also switching from Jigsaw's Daytrader DOM to Sierra's one. I've just seen the video you've attached and I've noticed that the recent bid volume column and the recent ask volume column in your SC DOM behave like the snapshot in Jigsaw's DOM. I can't get this result in my SC DOM: in mine, volumes don't really add up the way Jigsaw's DOM does. Would you mind sharing your settings ? |
