Date/Time: Tue, 26 Nov 2024 21:31:47 +0000
sierra chart connection
View Count: 249
[2023-10-17 14:04:32] |
estivenmarte00 - Posts: 2 |
I don't have a connection on my sierrachart platform, and I don't know why?
[2023-10-17 14:55:26] |
Sierra_Chart Engineering - Posts: 17185 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
