Date/Time: Tue, 26 Nov 2024 21:36:36 +0000
Text/CSV Data Format - Auto data refesh
View Count: 271
[2023-10-17 13:22:13] |
kubota - Posts: 1 |
Dear Sir/Madam, I live in Vietnam. I plan to use SierraChart to analyze Vietnam stock data. I can automatically generate data in Text/CSV Data Format. However, I have a question: Can SierraChart automatically reload data in real time? So that I can use features like OrderFlow/Footprint,... with SierraChart. Thank you so much |
[2023-10-17 18:09:10] |
John - SC Support - Posts: 36308 |
No. You really need to write the data in this format: Intraday Data File Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-19 10:04:44
