Date/Time: Mon, 16 Sep 2024 19:25:44 +0000
Futures custom spreads
View Count: 244
[2023-10-17 12:28:14] |
User370531 - Posts: 53 |
I see the instructions for creating a custom spread using the bar difference study. However, that would not be exactly accurate for the high and low of each bar, since the high and low might take place at different times within a bar for each symbol. Is it possible to get a true spread chart that is built out of tick level differences between two symbols?
[2023-10-17 18:07:17] |
John - SC Support - Posts: 34454 |
Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
