Date/Time: Tue, 26 Nov 2024 21:36:32 +0000
fair value gap
View Count: 780
[2023-10-17 10:09:30] |
User220939 - Posts: 36 |
Bonjour, Je voudrais tracer automatiquement les fair value gap. Est ce qu'il y a un moyen d'y arriver sans coder, et si oui quelle étude faut il utiliser? Cdlt |
[2023-10-17 17:44:15] |
John - SC Support - Posts: 36308 |
From Google Translate: I would like to automatically plot the fair value gap.
Is there a way to do this without coding, and if so what study should I use? We do not have a "Fair Value Gap" indicator directly in Sierra Chart. You can use the Spreadsheet Study or create an Alert to test for this. Refer to the following: Working with Spreadsheets Study/Chart Alerts And Scanning There is also the following post that talks about a third party Fair Value Gap indicator that you might be able to use, or use the code to create your own: Fair Value Gap indicator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-18 06:40:11] |
J'ai essayé de coder un indicateur, mais je n'ai pas réussi à l'intégrer à sierra. Pouvez vous me donner la marche à suivre? |
[2023-10-18 14:57:13] |
From Google Translate: I tried to code a flag, but couldn't get it into sierra.
Can you give me the procedure to follow? Refer to the following: How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
