Date/Time: Mon, 16 Sep 2024 19:06:55 +0000
Add SOFR to 3mo Tbill futures intercommodity spreads to SC symbols list
View Count: 258
[2023-10-16 19:41:07] |
User480109 - Posts: 36 |
I see that SC has added the outrights for CME new 3mo tbill futures. Please add the ICS intercommodity spreads symbols as well. Specifically the SR3Z23-TBZ23 SR3H24-TBH24 SR3M24-TBM24 SR3U24-TBU24 Thanks |
[2023-10-17 03:38:02] |
Sierra_Chart Engineering - Posts: 16387 |
You can request all of the spreads for the SR3 contract by going to File >> Find Symbol>> Futures-CME >> SR3. And then press the Get Spreads button refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-17 17:42:44
