Date/Time: Tue, 26 Nov 2024 22:22:12 +0000
Fills from DOM replicated on charts in a different install folder of SC (same computer)
View Count: 262
[2023-10-16 18:45:04] |
User999835 - Posts: 33 |
I have two Sierra Chart folders/separate installs on a single computer: "Trading" and "Charts" "Charts" has just my charts "Trading" has just my DOMs/ladders Is it possible to have the trades/fills i placed on the DOMs in the "Trading" installation replicated on the charts running in the "Charts" installation? I am currently in SIM to get the hang of SC ladders but will switch soon to Teton. From a performance standpoint, is it best to have two separate installations/folder of Sierra Chart or have one main installation and one instance run from the main install folder? if the latter, would you recommend to have the DOM as the main install folder (and charts running in the instance off the main install)? Thank you Rgds |
[2023-10-16 20:00:40] |
John - SC Support - Posts: 36309 |
There is not a way to get the trade information between the installations while using the built-in Simulation Mode. But you could get this is you use the "Simulated Futures Trading Service", as long as both installations are set to the same service and the same account. Refer to the information at the following link: Simulated Futures Trading Service And when you are in live trading, you will not have the issue as well, again just as long as both installations are connecting to the same trading service and account. Refer to the following for information on setting up for low latency trading: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
