Date/Time: Fri, 22 Nov 2024 08:41:21 +0000
Cgarts
View Count: 1757
[2013-05-03 19:41:57]
Ed Meckelborg - Posts: 71
My stock charts start at 00:00:0, I would like to have them start at 9:30 and end at 16:00.
How do I set the program to reflect the above parameters. I can change the settings but I have to do that for every chart and every morning. I us IB.
[2013-05-03 22:43:11]
Refer to the documentation for Session Times here:
http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes
After you set up your charts, save them as a Chartbook as documented here:
http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html
You can also set these Session Times as a default for new stock charts by editing the Global Symbol Settings:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php
