Date/Time: Tue, 26 Nov 2024 22:42:49 +0000
Footprint chart
View Count: 252
[2023-10-16 14:35:55] |
tradersim1 - Posts: 1 |
Hi, Could you please help me with footprint setup? I want to make the same footprint chart as in the attachment. I did the box (circled in green) but I don't know how to set up the profile next to it (circled in red). Could you please help? |
IMG_20231016_173302_edit_988963095873571.jpg / V - Attached On 2023-10-16 14:34:11 UTC - Size: 45.54 KB - 91 views Attachment Deleted. |
[2023-10-16 16:13:21] |
John - SC Support - Posts: 36309 |
The second column is setup using the "Column 2" options. Numbers Bars give you the ability to configure up to 3 columns to display various data. In this case, you are wanting to setup 2 columns. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
