Date/Time: Tue, 26 Nov 2024 22:34:43 +0000
unable to activate cme on 2nd system
View Count: 233
[2023-10-16 13:24:51]
User203340 - Posts: 9
im trying to activate cme for 2 systems but keep getting error message in the attached file.what should i do
image1.png / V - Attached On 2023-10-16 13:24:19 UTC - Size: 56.83 KB - 72 views
[2023-10-16 13:50:11]
Sierra_Chart Engineering - Posts: 17185
We need some time to look into this and determine a solution.
[2023-10-16 15:26:54]
Sierra Chart - Max - Posts: 5731
You should now be able to set your account for 2 systems here:
When an additional system is activated, you will be charged 27.5 USD, which is the total for your currently active exchanges.
Sierra Chart Support
[2023-10-16 15:30:09]
You can activate the second system now for exchange fees.
