Date/Time: Tue, 26 Nov 2024 22:39:18 +0000
DTC Protocol Server settings
View Count: 249
[2023-10-15 16:51:43] |
User899259 - Posts: 2 |
I am using sub-instances of SC. What is "Network Socket Delayed Send Interval in Milliseconds" in the DTC Protocol Server settings window? Is this related to Nagle's algo or TcpAckFrequency in anyway? The default is "0", does that mean no delay? Windows Server 2016 Teton/Denali Date Time Of Last Edit: 2023-10-15 16:53:46
[2023-10-15 18:51:40] |
Sierra_Chart Engineering - Posts: 17185 |
That should be 0. It would also have no effect in a sub instance. In the main instance it should be 0 to ensure there is no delay with sending data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-15 18:52:02
