Date/Time: Fri, 25 Sep 2026 21:53:36 +0000
[Programming Help] - Saving Subgraph.DrawStyle to a variable to be updated within ACSIL study
View Count: 1000
[2023-10-15 10:13:25]
User92573 - Posts: 615
Dear Support/Support Board
Can someone help me solve this?
I need to save Subgraph.DrawStyle to a variable so that I can recall it, or change it, based on a selection, or outcome within my study - without changing the default setting.
//Here is an example to illustrate what I'm trying to achieve:
if (sc.SetDefaults)
  Subgraph_01.Name = "01";
  Subgraph_01.DrawStyle = DRAWSTYLE_DASH;
  return;
// Do Processing
SET A VAR as my_Drawstyle
if(Set_Drawstyle == 1)
  //Subgraph_01.DrawStyle = DRAWSTYLE_POINT; ... This would lose, or change the default.
  my_Drawstyle = DRAWSTYLE_POINT;
else if(Set_Drawstyle == 2)
  //Subgraph_01.DrawStyle = DRAWSTYLE_HIDDEN; ... This would lose, or change the default.
  my_Drawstyle = DRAWSTYLE_HIDDEN;
else
  my_Drawstyle = ... get .. Subgraph_01.DrawStyle // This would reset my Subgraph_01.DrawStyle parameters to the default setting.
// Now set Subgraph_01.DrawStyle to the selected DrawStyle.
Subgraph_01.DrawStyle = my_Drawstyle; //
What I'd like to do is retain the initial default settings but change the DrawStyle depending on an outcome in my ACSIL study.
Any help appreciated.
Many thanks
[2023-10-19 23:42:37]
ForgivingComputers.com - Posts: 1238
if (sc.SetDefaults)
return;
// Do Processing
// Save Original DrawStyle
int Orig_DrawStyle;
if (sc.Index == 0)
  Orig_DrawStyle = Subgraph_01.DrawStyle;
else
  // Use the saved value of the default drawstyle
  my_Drawstyle = Orig_DrawStyle; // This would reset my Subgraph_01.DrawStyle parameters to the default setting.
Date Time Of Last Edit: 2023-10-19 23:50:56
[2023-10-20 13:30:27]
Thank you I didn't think of that. I thought it would be an enum list of some form.
Great thanks.
I don't suppose you have any thought on the other Support Board Post?
How to hide/show "sc.AddAndManageSingleTextDrawingForStudy"
