Date/Time: Tue, 26 Nov 2024 22:41:36 +0000
[Tick size] and [Currency Value per Tick] keep resetting themselves
View Count: 485
[2023-10-15 02:17:10]
Ifrit - Posts: 51
Under Chart Settings:
Tick Size
Currency Value Per Tick
These settings keep resetting themselves after Sierra Chart closes (even with Save All prompt). Auto-Set From Data feed is set to [No] and never sets itself to [Yes].
Each time I reboot Sierra Chart I have to F5 into Chart settings and reset both settings. I am trying to make the tick size 4x large on NQ and setting the currency value per tick to 4x as well so they both match.
Any idea why this is happening? I have to do it for both NQ and MNQ on two separate charts. Changing datafeed or putting them in their own chartbooks doesn't solve the problem either.
[2023-10-15 18:06:48]
Sierra_Chart Engineering - Posts: 17185
Do you know is the symbol of the chart changing at any time?
Are you using Chart Linking?
[2023-10-15 18:54:56]
Ifrit - Posts: 51
Yes, Chart Linking is Enabled.
It links the following:
Symbol
Session Times
Trade window
Trade/Quote Symbol
Time Zone
One chart had "Auto-Set From Data Feed" set to [Yes] and the one that auto-changed had "Auto-Set From Data Feed" to [No], but perhaps it was pulling from the other chart?
I disabled the "Auto-Set" toggle on the one chart and this seems to have solved the problem on the other.
Thank you.
Date Time Of Last Edit: 2023-10-15 18:55:42
