Date/Time: Tue, 26 Nov 2024 22:20:32 +0000
Studies frozen in place but not drawings and price
View Count: 310
[2023-10-14 22:34:19]
Bricolico - Posts: 3
Hello group,
I've been searching the solution for this problem for hours now and havent been able to find how to fix it.
I have a chartbook with 5 windows: 4 different timeframe and 1 footprint.
The problem is on one of my intraday chart only. By example, when I manually adjust the scale (left click on the scale) of the price up and down (right side of window), the candles are moving good but for an unknow reason, the studies just stay in place without moving. They're not following the price adjustment I'm doing with the mouse. All other charts are working fine.
- I compared 'chart settings' of another chartbook to see where the problem is but everything is all the same.
- I tried to change the timeframe but nothing changed
- I 'reloaded and recalculated' everything but nothing changed
- I restarted Sierra Chart but nothing changed
- I cleaned chart and reloaded all studies but nothing changed
- I searched for any STUDY settings for this specific chart but havent found anything relevant.
- I tried to duplicate the chart but the problem duplicate as well
- I created another intraday chart from scratch and that was successful but because I have few drawings on the original chart, I'd really like to find the solution to my problem instead of having to create a new chart.
I recently played with the REPLAY CHART function but I doubt my problem come from there.
I probably adjusted a setting by mistake and here I am with this problem. Is there any settings existing that could freeze studies in place and that I could 'unfreeze' them all back to normal please? I'm on this since too long (3-4 hours).
Thanks in advance for you precious help.
[2023-10-14 22:58:54]
Sierra_Chart Engineering - Posts: 17185
This is a scale related issue.
Refer to:
Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region
