Date/Time: Mon, 28 Sep 2026 00:26:12 +0000
sc.SetChartStudyTransparencyLevel not working
View Count: 1352
[2023-10-14 01:51:20]
Mark Lewis - Posts: 27
This new function isn't working for me.
if (sc.SetDefaults)
sc.SetChartStudyTransparencyLevel(sc.ChartNumber, sc.Input[0].GetStudyID(), 45);
Also, I haven't found any documentation other than a few references on the support boards.
Thanks!
[2023-10-14 17:48:24]
I got it to work using the code below. I'm thinking the study ID isn't available when sc.SetDefaults code is run.
if (sc.StudyGraphInstanceID != 0 && sc.Index == 0)
sc.SetChartStudyTransparencyLevel(sc.ChartNumber, sc.StudyGraphInstanceID, 72);
Hope that helps someone else :)
[2023-10-14 20:05:25]
Ok, so the last post works but overwrites changes to transparency made by the user.
Where should sc.SetChartStudyTransparencyLevel() be called to set a default and allow user changes?
[2023-10-14 20:45:22]
Sierra_Chart Engineering - Posts: 24993
This is the code to use:
However, currently this is not going to work in the sc.SetDefaults code block. We are adding support for that but it is not so simple.
Date Time Of Last Edit: 2023-10-14 20:45:31
[2023-12-30 06:38:44]
SavantTrader - Posts: 112
Dear SC Engineering:
On 2023-10-14 you mentioned that sc.SetChartStudyTransparencyLevel would not work in the sc.SetDefaults code block, and that you were adding support for it.
As we move into 2024, can you please give me a status update on supporting it in sc.SetDefaults, please.
Thank you.
[2023-12-30 09:03:32]
From what we see support has been added to use that function in the sc.SetDefaults code block. Go ahead and try.
And we have confirmed, that it actually does work.
Date Time Of Last Edit: 2023-12-30 09:08:31
