Date/Time: Tue, 26 Nov 2024 22:32:29 +0000
Historical Data not loading
View Count: 270
[2023-10-13 20:49:53] |
gooby321 - Posts: 1 |
So I use APEX for my trade execution and I have intraday and historical data empty for the logins. I am tried to create one continuous contract (volume based roll over) for my TPO chart since I want all the past data. The main problem I am having is that when I go back as far as I can my tpo chart skips back to ESZ2 (a year) instead of the contract before ESZ3. Did I set up my continuous contract wrong or should I wait for Denali data feed (currently on rithmic limited data feed) to download that big continuous contract?
Date Time Of Last Edit: 2023-10-15 06:20:29
[2023-10-16 14:18:49] |
John - SC Support - Posts: 36309 |
If you are using the Rithmic data, you will definitely not be able to get the data going back that far. As to why you have data for ESZ2, our only guess is that you happened to have that data from prior, but we really can not say. In order to get the data, you will need to use the Denali Exchange Data Feed. We see you have setup and activated the "CME Top-of-Book for Non-Professionals" exchange, so you should be good now. If you do not have the data filling in, then follow these instructions to redownload the data for that chart: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
