Date/Time: Tue, 26 Nov 2024 22:35:17 +0000
Show todays Volume Profile on the far right, but the others on the left of each session
View Count: 445
[2023-10-13 18:40:23]
mojsterr - Posts: 26
I have Volume Profiles that are shown for each day, on the left side, for each session.
I have put another Volume Profile (for the current day) on the far right side.
Is it possible to have the last day on the far right, but not also on the left, for this day? At the moment there are two for today, which show the same thing, and it is too much.
All the previous days should be on the left, just this last day one should be positioned on the far right.
Is it possible?
Thank you.
Date Time Of Last Edit: 2023-10-13 18:57:25
[2023-10-13 20:09:04]
John - SC Support - Posts: 36309
It sounds like you have two copies of the Volume by Price study on your chart, one with multiple profiles and one with a single profile for the current day that is aligned to the right.
What you can do is remove the second one that is a single profile and then in the study with multiple profiles, set the following Inputs:
- Right Align Volume Bars: Yes (this is not absolutely necessary, but is helpful).
- Always Display Last Profile Within View: Yes
[2023-10-14 05:45:23]
Yeah, but now all the others are on the right of each session as well.
I guess it's ok. I'll do it like it is then.
