Date/Time: Tue, 26 Nov 2024 22:13:24 +0000
Trading
View Count: 344
[2023-10-13 16:56:16] |
JR2500 - Posts: 2 |
I am trying to find out if I can just use Sierra Chart for data and to place trades. Do I have to use a 3rd party broker in order to make trades like Ninja Trader or Think or Swim or something like that? Or with the service and data package from SC can you just use this for everything??
[2023-10-13 16:58:40] |
John - SC Support - Posts: 36309 |
You need a broker. Sierra Chart is not a broker, so you can not make trades through us.
[2023-10-13 17:09:07] |
JR2500 - Posts: 2 |
Any recommendations of what broker works best with the Sierra Chart platform?
[2023-10-13 17:22:01] |
We recommend any broker that supports our Teton Order Routing service, although this only works with the CME Group. Refer to the general information at the following link: Sierra Chart Teton Futures Order Routing The list of supporting brokers is in Step #2 of the Setup Instructions on the above page, which can be accessed directly through the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions Otherwise, any broker that supports CQG or Rithmic can be used with Sierra Chart (except Tradeovate and Ninja Trader), along with Interactive Brokers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
