Date/Time: Tue, 26 Nov 2024 22:32:55 +0000
[User Discussion] - attached orders addition to a position
View Count: 304
[2023-10-13 10:18:47] |
SkyKeeper - Posts: 40 |
Tell me if there is a setup for attached orders. When is there an addition to a position so that stop orders and target orders are set to the level of existing orders at their price? Now they are set from the current price
[2023-10-13 15:08:57] |
John - SC Support - Posts: 36309 |
We are not sure we are fully understanding what you want, but it sounds like you want the "Scale In" option. Refer to the following: Attached Orders: Scaling In For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-14 05:40:50] |
Thank you, I think this is what I need
