Date/Time: Tue, 26 Nov 2024 22:34:37 +0000
support for ALI on COMEX
View Count: 295
[2023-10-13 02:48:30] |
voided - Posts: 45 |
Hi, I don't see aluminum (ALI) available on Sierra Chart. Could you add this symbol? https://www.cmegroup.com/markets/metals/base/aluminum.html |
[2023-10-13 13:18:05] |
Sierra_Chart Engineering - Posts: 17185 |
Yes we will add this.
[2023-10-13 16:29:08] |
This will go into effect over the weekend. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
