Date/Time: Tue, 26 Nov 2024 22:13:38 +0000
[Programming Help] - Subgraph is not updating after a custom menu event
View Count: 290
[2023-10-13 02:31:51]
Mark Lewis - Posts: 25
I have pieced together some code so that I select a user drawing (rectangle in this case), right-click and choose my custom menu item. The code triggers a message to the log with the drawing information but I cannot update my subgraph (Subgraph_BalanceZoneTop) to the value retrieved by the code capturing the event. Also, when I add the custom study it puts the subgraph line (Subgraph_BalanceZoneTop ) at 0. How can I fix these two issues? I have searched and searched the custom study examples. Thanks!
#include "sierrachart.h"
SCDLLName("My Studies")
SCSFExport scsf_BalanceZones(SCStudyInterfaceRef sc)
  SCString MessageText;
  SCSubgraphRef Subgraph_BalanceZoneTop = sc.Subgraph[0];
if (sc.SetDefaults)
    sc.GraphName = "Balance Zones";
    sc.StudyDescription = "";
    sc.GraphRegion = 0;
    Subgraph_BalanceZoneTop.Name = "Balance zone top";
    Subgraph_BalanceZoneTop.DrawStyle = DRAWSTYLE_LINE;
    Subgraph_BalanceZoneTop.PrimaryColor = RGB(127,0,0); // Dark red
    Subgraph_BalanceZoneTop.DrawZeros = true;
return;
  int& r_MenuID = sc.GetPersistentInt(1);
  if (sc.LastCallToFunction)
    sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, r_MenuID);
    return;
  if (sc.UpdateStartIndex == 0)
    if (r_MenuID <= 0)
      r_MenuID = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Balance zones");
    return;
  s_UseTool ChartDrawing;
  if (sc.MenuEventID != 0 && sc.MenuEventID == r_MenuID)
    int selectedLineNumber = sc.GetLineNumberOfSelectedUserDrawnDrawing();
    sc.GetUserDrawnDrawingByLineNumber(0, selectedLineNumber, ChartDrawing);
    float BalanceZoneHeight = ChartDrawing.BeginValue - ChartDrawing.EndValue;
    Subgraph_BalanceZoneTop[sc.Index] = ChartDrawing.BeginValue;
    SCString BeginDateTimeString = sc.FormatDateTime(ChartDrawing.BeginDateTime);
    SCString EndDateTimeString = sc.FormatDateTime(ChartDrawing.EndDateTime);
    SCString Msg;
    Msg.Format("Drawing was selected: BeginDateTime=%s, EndDateTime=%s, BeginValue=%f, EndValue=%f, Height=%f." , BeginDateTimeString.GetChars(), EndDateTimeString.GetChars(), ChartDrawing.BeginValue, ChartDrawing.EndValue, BalanceZoneHeight);
    sc.AddMessageToLog(Msg, 1);
    return;
Date Time Of Last Edit: 2023-10-13 02:33:35
[2023-10-13 18:26:26]
Okay, I've made a bunch of changes to utilize settings' inputs because I realized I needed to save the value. My input is updated by the right-click menu event, but the subgraph is not drawn in less I open up the settings for the study and click okay. Any ideas?
  SCSubgraphRef Subgraph_BalanceZoneBottom = sc.Subgraph[1];
  SCInputRef BalanceHigh = sc.Input[0];
  SCInputRef BalanceLow = sc.Input[1];
if (sc.SetDefaults)
    sc.DrawZeros = 0;
    sc.GraphRegion = 0;
    sc.ValueFormat = 3;
    sc.AutoLoop = 1;
    Subgraph_BalanceZoneBottom.Name = "Balnce zone bottom";
    BalanceHigh.Name = "Balance high";
    BalanceHigh.SetFloat(0);
    BalanceLow.Name = "Balance low";
    BalanceLow.SetFloat(0);
return;
    return;
    if (r_MenuID <= 0)
      r_MenuID = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, "Draw balance zones");
    return;
    BalanceHigh.SetFloat(ChartDrawing.BeginValue);
    BalanceLow.SetFloat(ChartDrawing.EndValue);
  float BalanceHighVal = BalanceHigh.GetFloat();
  float BalanceLowVal = BalanceLow.GetFloat();
  Subgraph_BalanceZoneTop[sc.Index] = BalanceHighVal;
  Subgraph_BalanceZoneBottom[sc.Index] = BalanceLowVal;
[2023-10-13 19:12:24]
Ahhh, calling sc.RecalculateChart() after the drawing values are retrieved solves the issue. Relevant code below.
    sc.RecalculateChart(0);
