Date/Time: Tue, 26 Nov 2024 22:38:46 +0000
Display ATR from a chart on a DOM
View Count: 258
[2023-10-12 22:10:45] |
User449884 - Posts: 155 |
Ive used study overlay alot, but i cant get the ATR value from a specific chart on my DOM. Either at the top or side etc
[2023-10-13 14:59:48] |
John - SC Support - Posts: 36309 |
What exactly are you wanting to see from the ATR? If you just want the value of the last bar, then use the "Text Display for Study from Chart". Refer to the following: Text Display For Study from Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
