Date/Time: Tue, 26 Nov 2024 22:30:19 +0000
Teton Order Routing with CME and EUREX
View Count: 637
[2023-10-12 18:14:40]
User999835 - Posts: 33
I currently trade instruments on both CME and EUREX exchanges with the following: frontend==Jigsaw ladders, order routing==CQG, broker==AMP, charts==Sierra/Denali.
I would like to switch and use: frontend==SierraChart ladders, order routing==Teton, broker==AMP, chart==Sierra/Denali.
I understand how to do this with CME instruments (First Sierra instance using Teton Order Routing).
I also understand that Teton does not support order routing to EUREX; does this mean that to keep trading EUREX instruments, I need a second instance of Sierra that uses CQG/WebAPI in Data/Trade Service?
Could i have a third instance for charts purpose that uses Denali?
For instances 1/CME and 2/EUREX, will it be Denali displaying market depth in the Sierra Chart ladders?
Thank you
Rgds
[2023-10-12 18:34:33]
John - SC Support - Posts: 36309
Yes, this is correct. Refer to the following for how to install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Yes, this is not a problem. But you will want to have both the Second and Third instances on the same computer as the first instance. This will allow you to get the Denali data to all three instances. Otherwise, if you use a second computer, you will have to pay an additional set of exchange fees to get the data to both systems. Refer to the information at the following link:
Denali Exchange Data Feed: Connections
Yes, as Denali is the only data you can get when you are connected to Teton or CQG (we do not support data from CQG for the CME Group and EUREX).
[2023-10-13 16:02:06]
Thank you very much, one more set of questions please... In terms of fees and set-up, I would have to pay the usual fees to Sierra Chart ie: Sierra Chart software + Denali fees for CME and EUREX
and to AMP broker, I would have to pay and setup the following:
- First request for Live Trading Setup: "Teton (Sierrachart)" - no fee (this is the order routing to CME)
- Second request for Live Trading Setup: "Sierra Chart - Denali - CQG (No Data - Order Routing Only) - EUREX - 20 EURO p/m (this is the separate order routing via CQG to EUREX)
Is this correct please?
Thank you Rgds
[2023-10-13 16:20:47]
Yes, what you state is correct.
[2023-10-13 17:59:45]
Thank you for clarifying and confirming, much appreciated.
