Date/Time: Tue, 26 Nov 2024 22:15:56 +0000
Cannot find ACSIL to Show/Hide an individual Tool.Level[ ]
View Count: 288
[2023-10-12 14:30:43]
User92573 - Posts: 530
Dear Support
I've looked through the documentation and the header file .h but cannot locate the the means to replicate the "Show Levels" checkbox as can be seen/selected in the retracement tools and similar.
  //.h
  DrawingType = DefaultUseTool.DrawingType;
  LineWidth = DefaultUseTool.LineWidth;
  LineStyle = DefaultUseTool.LineStyle;
  // SCSFExport scsf_UseToolExampleRewardRisk(SCStudyInterfaceRef sc)
  Tool.LevelColor[0] = COLOR_DARKRED;
  Tool.LevelStyle[0] = LINESTYLE_SOLID;
  Tool.LevelWidth[0] = 2;
  // But no equivalent to Hidden
  // I can select exclude code block to comment out the block for that level but then I cannot reselect/make visible when the tool is selected.
Please can you provide example ACSIL code to set individual levels to show/hide.
Many thanks.
Date Time Of Last Edit: 2023-10-12 14:36:51
[2023-10-12 14:43:17]
User431178 - Posts: 543
Using Drawing Tools From an Advanced Custom Study: s_UseTool::RetracementLevels[]
Set the relevant value(s) in the RetracementLevels array to FLT_MAX
[2023-10-12 16:35:35]
Hi, thank you but not the solution I was looking for as it loses the set value.
The sc tool has a simple check box alongside each level that either shows/or hides the individual preset level. It doesn't require the float value be set to [0].
I'm looking for the the code to access the Show/Hide without changing preset level values.
Not in .h or structures.
It was queried years ago here:
Hide Retracement Levels for a Price Retracement Drawing using ACSIL
But I cannot find any reference to ShowLines[] in the header, and still no way to initially set a specific line/level to hide.
Hopefully Engineering will revisit the post.
Date Time Of Last Edit: 2023-10-12 17:11:04
[2023-10-12 17:41:44]
Maybe not, but it is the only ACSIL accessible solution that currently exists.
