Date/Time: Tue, 26 Nov 2024 22:39:22 +0000
Hide / Disable Close on Control Bars
View Count: 266
[2023-10-12 12:01:05]
User92573 - Posts: 530
Dear Support
Is there a way to Hide / Disable the Close "X" on Control Bars.
I'd like to disable it so the control can only be closed via the Window >> Control Bar ... selection.
It very easy to accidentally close a toolbar when quickly working through charts and chart books.
Many thanks.
[2023-10-12 14:46:01]
John - SC Support - Posts: 36309
We assume you are referring to when the Control Bar is "floating".
In this case, there is not a way to disable the "x" that closes the Control Bar.
