Date/Time: Tue, 26 Nov 2024 22:13:22 +0000
MY NUMBERS BARS VOLUME PROFILE IS DIFFERENT FROM THE CHART VOLUME PROFILE
View Count: 290
[2023-10-12 10:57:31] |
User130417 - Posts: 13 |
i HAVE BEEN HAVING THIS PROBLEM AND SEEKING WAYS TO RESOLVE THE VOLUME PROFILE ANOMALY BETWEEN MY NUMBERS BARS AND THE CHART FOR CRUDE AND ES MINI; ITS SO CONFUSING NOT KNOWING WHICH ONE DEPICTS THE RIGHT INFORMATION FOR ME TO TRADE WITH ME. PLEASE HELP, TO RESOLVE THIS ISSUE.
[2023-10-12 14:44:22] |
John - SC Support - Posts: 36309 |
They should be the same as long as you have set them to display the exact same information. Please give us a screenshot of what you are seeing with the two profiles. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-13 12:47:48] |
I HAVE ATTACHED THE SCREEN SHOTS FOR CRUDE OIL, ALSO VERY APPLICABLE TO ES; I CAN ONLY ATTACH JUST WHAT IS ALLOWABLE. THE VALUES ON THE VOLUME PROFILE ON THE CHART ALSO DIFFERENT FROM THE NUMBERS BARS. |
Private File Private File Private File |
[2023-10-13 15:18:34] |
What is the period for the Volume by Price study? The volume profiles within the Numbers Bars are for each bar. It does not look like you have a single bar period for the Volume by Price profile, therefore these are not going to match up. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-13 16:19:06] |
How do i set the volume profile to have a single bar period in the numbers bars please?
[2023-10-13 16:23:13] |
Refer to the following for how to have multiple Volume by Price Profiles, one for each bar: Volume By Price Study: One Volume Profile per Chart Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
