Date/Time: Tue, 26 Nov 2024 22:13:50 +0000
Control what's displayed in the status/title bar
View Count: 234
[2023-10-12 10:40:47] |
FuturesBod - Posts: 16 |
Can somebody tell me how to control what's displayed (see image attached). Specifically I want it to show the OHLC of the bar the Chart Values pointer is resting on. Thanks! |
Screenshot 2023-10-12 123605.png / V - Attached On 2023-10-12 10:40:33 UTC - Size: 7.44 KB - 66 views |
[2023-10-12 14:40:32] |
John - SC Support - Posts: 36309 |
Refer to the following for how to modify the Chart Header: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) There is not an option for it to show the values that the crosshairs are pointing to. To do this, you would want to use the "Compact Tool Values Window", and you can set it to a horizontal orientation so it will essentially mimic what you are wanting. Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-12 14:43:06] |
Great, thank you John.
