Date/Time: Tue, 26 Nov 2024 22:39:39 +0000
right side of Graph vanishes if shifting it to the right hours before the current time.
View Count: 215
[2023-10-11 19:23:47] |
User408639 - Posts: 69 |
Moin Moin. As I did not find anything in the SC-boards or using google and ChatGPT, I wanted to ask how to stop the graph inside a chart from not being rendered beyond a certain time if I am shifting it to the right, in order to see more of the past. In order to clarify it, I did attach.: 1. the link-settings, 2. a screenshot, 3. a short video. Cheers, Michael. Date Time Of Last Edit: 2023-10-11 19:28:13
link-settings.png / V - Attached On 2023-10-11 19:23:30 UTC - Size: 21.16 KB - 71 views right side of Graph vanishes if shiftinmg it to the right ho.png / V - Attached On 2023-10-11 19:23:36 UTC - Size: 149.08 KB - 62 views Private File |
[2023-10-11 20:41:44] |
John - SC Support - Posts: 36309 |
You have the option for "Lock Fill Space" enabled, which is why the data does not show into the right side of the chart. Refer to the following: Chart Menu: Lock Fill Space (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
