Date/Time: Tue, 26 Nov 2024 22:39:19 +0000
Color Bar Background Based on Alert Condition
View Count: 279
[2023-10-11 15:05:36] |
User940772 - Posts: 74 |
I'm not sure if this is a violation of the board rules or not but I am trying to write a simple Color Bar Background Based on Alert Condition for a couple of Numbers Bar Calculated Values stats that use percentages. Specifically AskVol BidVol Difference Percent and Finish AskVol BidVol Diff% and nothing I have tried works. Seems simple but can't figure it out. How the heck do you write percentages for alert conditions.
[2023-10-11 15:35:56] |
John - SC Support - Posts: 36309 |
The Numbers Bars Calculated Values have some special requirements, percentages are one of these. Refer to the following: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-11 15:45:10] |
Seems like I was looking for help in the wrong place, under Alert Conditions and not Numbers Bars Calculated Values. Thanks John |
