Date/Time: Fri, 22 Nov 2024 08:48:20 +0000
[User Discussion] - double checking alert
View Count: 2968
[2013-05-03 19:32:45]
M5amhan - Posts: 468
if i wanted to reference the high going 20 ticks above a study i would write =(H+(TICKSIZE20)>ID1.SG1) correct? thank you
[2013-05-03 22:40:57]
Sawtooth - Posts: 4118
Try this:
=H+(TICKSIZE*20)>ID1.SG1
[2013-05-04 00:45:55]
it looks like this code takes the high and adds 20 ticks to it
[2013-05-04 01:23:41]
Yes, it goes TRUE when the High + 20 ticks is greater than the study.
Date Time Of Last Edit: 2013-05-04 03:19:04
[2013-05-04 01:27:47]
how can i make it true when the high is 20 ticks above the study
[2013-05-04 03:22:01]
Try this:
=H>ID1.SG1+(TICKSIZE*20)
[2013-05-04 03:29:41]
thank you that worked.. i also just thought about =H-(TICKSIZE*20)>ID1.SG1 either way, thanks for helping
[2013-05-04 03:58:18]
One way to visually test alert formulas is to put the formula in a Color Bar Based On Alert Condition study.
[2013-05-04 04:02:20]
that is how im using it for running a few statistical tests.. is there a way to run this through a spreadsheet and return how many days a month it comes back true? this would also help me a lot rather than manually going through years of data
[2013-05-04 05:02:35]
i tried this but its not working
=DCOUNT(C3>HX3+($J$21*$20))
[2013-05-04 05:25:12]
I don't think you are using the correct syntax:
http://office.microsoft.com/en-us/excel-help/dcount-HP005209049.aspx?CTT=5&origin=HP005204211
