Date/Time: Tue, 29 Oct 2024 16:43:39 +0000
Sierra Chart Connectivity to Data and Trading Services
View Count: 4601
[2013-06-19 20:19:50] |
WarriorTrader - Posts: 245 |
Hello, Any word on the OEC FIX connection? I noticed that the OCE data (bid/ask cummulative delta) has been much more stable over the past few weeks. I guess OEC made some changes on their end? Thx, WT Date Time Of Last Edit: 2013-06-19 20:23:31
[2013-06-19 20:35:53] |
We are getting closer to getting OEC FIX done. It has been set aside for a while because we had some difficulty with the FAST protocol and have to do the processing on a background thread. We are definitely getting very close though to achieving all of the critical improvements that we need. While from the user's perspective, they may not see a lot of change in Sierra Chart, internally everything is significantly improved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-23 08:00:09] |
Fraois - Posts: 12 |
Still no plan on CQG? CME Europe is going live, but Rithmic does not support it and does not have a server in Equinix LD4/5. The only way out is CQG. Will Sierra Chart reconsider again on CQG? Or can you help pressure Rithmic to cross-connect their server with CME in LD4/5, Slough?
[2013-10-23 11:05:49] |
AndyL - Posts: 119 |
Fraois: i wouldn't hold my breath for CME Europe. They postponed the launch 2 times already and now dont even give a new launch date. I also talked to a few futures brokers, and all said, they will not initally support it, but first see how liquid the products are and only add later on it if there is client demand.
[2013-10-23 18:34:42] |
We do not plan CQG. We already support many trading and data services. We do plan to add support for Teletrader.
