Date/Time: Tue, 26 Nov 2024 22:12:49 +0000
Farb- plus Pfeilauswahl
View Count: 229
[2023-10-11 13:01:10]
User22414 - Posts: 66
Entsprechend der Neigung des MovAV kann man durch ->Based on Slope der fallenden Kurve (zum Beispiel ->rot) / oder der steigenden Kurve (zum Beispiel ->gelb) eine Farbe zuordnen.
Dieses Tableau der Farbauswahl sollte um eine Pfeilauswahl ergänz werden. Zu ->rot sollte eine Zuordnung/ die Auswahl eines Pfeiles = Down-Pfeil, zu -->gelb = Up-Pfeil möglich sein. Das Ergebnis ist dann keine Line des MovAv, sondern eine Folge von gleichgerichteten Pfeilen, in Richtung des Kursesverlaufes.
Date Time Of Last Edit: 2023-10-11 15:05:30
[2023-10-11 15:10:18]
John - SC Support - Posts: 36309
From Google Translate:
According to the slope of the MovAV, you can assign a color to the falling curve (for example ->red) / or the rising curve (for example ->yellow) using ->Based on Slope.
This tableau of color selection should be supplemented by an arrow selection. It should be possible to assign/select an arrow to ->red = down arrow, to -->yellow = up arrow. The result is then not a line of the MovAv, but a sequence of arrows pointing in the same direction in the direction of the price trend.
You can do this by using two copies the "Color Bar Based on Alert Condition" study. One copy for an Up Arrow and another for the Down Arrow.
To test whether the Moving Average is moving Up or Down you would need to look at the current and previous values. To do this, you would use the following formula to test if it is an Up Moving (positive) slope:
=ID1.SG1[-1] < ID1.SG1
Refer to the following section of the Color Bar Based on Alert Condition documentation in particular:
Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars
