Date/Time: Tue, 26 Nov 2024 22:23:27 +0000
switch
View Count: 217
[2023-10-11 12:15:17] |
User768203 - Posts: 9 |
Hi, I am curently with CQG and would like to swicth to rithmic to open an account on apex and trade with the prop firm, wondering how to switch
[2023-10-11 15:03:55] |
John - SC Support - Posts: 36309 |
In general, to switch the information you just need to change the setup in the "Data/Trade Service Settings". In particular, for Rithmic, you would follow the instructions at the following link: Rithmic Trading Platform Service: Setup Instructions But, if you are actually going to be keeping the CQG account and you are also adding an account that uses Rithmic, then you would want to install a second Sierra Chart on your computer and then setup that second installation to connect to Rithmic using the instructions given above. This way, you will be able to connect to both accounts and trade them separately. Also, by having the two installations, it avoids issues with having to verify your "Non-Professional" standing with the CME Group, as they do not recognize Prop Firm accounts (such as APEX) for this purpose, so you would still need the account that uses CQG in order to continue to get the Denali Data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
