Date/Time: Wed, 30 Oct 2024 22:55:56 +0000
an idea for improvement
View Count: 959
[2014-07-18 14:54:49] |
mayerrs - Posts: 70 |
hi, just an idea. i would like to have in Chart Draving Menu for Chart Draving Properties the small arrow with the option to load TC1 .. TC8. same as in Color, Line style, Line Width. do you think this may be done? i am sure it would be faster for loading TC1 .. TC8 thanks |
[2014-07-21 22:04:45] |
This is currently supported. Refer to the documentation here for instructions: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ApplyingPredefinedConfiguration You can add any of the predefined Tool configurations to the Chart Drawing Shortcut menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
