Date/Time: Tue, 26 Nov 2024 22:30:16 +0000
DOM. Why is the line spacing different?
View Count: 291
[2023-10-11 05:32:01]
SkyKeeper - Posts: 40
One graph is created by a copy of the other. When you change the tool, the line spacing changes, although the font and size have not changed and it is set by global parameters. How to reduce the interval in the right graph? How to make the price stand tight?
Date Time Of Last Edit: 2023-10-11 05:32:54
image1.PNG / V - Attached On 2023-10-11 05:31:12 UTC - Size: 24 KB - 76 views
image2.PNG / V - Attached On 2023-10-11 05:32:52 UTC - Size: 22.85 KB - 70 views
[2023-10-11 14:20:05]
John - SC Support - Posts: 36309
We are not understanding what you mean by "when you change the tool". What tool are you changing that creates this change in the spacing?
[2023-10-13 10:09:12]
I solved the problem like this.
I copied from the defective window and got a normal one. Then I copied the normal back to the chart, and deleted the defective one.
Well, it was some kind of glitch.
