Date/Time: Tue, 26 Nov 2024 22:21:08 +0000
"Reset" on scale affect only left or right scale?
View Count: 270
[2023-10-11 01:18:58] |
methodtrades - Posts: 46 |
Is it possible for the "reset" option on the scale to only affect the side it is clicked on? I have my main price graph, and a CDV study on the same region. CDV using the left scale with custom settings. When I want to reset the price scale, it resets both. If there is no way to do this, any possibility these could be an option: 1. Double click on scale only resets that side 2. reset keyboard shortcuts for left/right sides" of the scale 3. Auto scale Chart DOM only affects right scale. Ty Date Time Of Last Edit: 2023-10-11 01:27:51
[2023-10-11 09:21:58] |
Sierra_Chart Engineering - Posts: 17185 |
No this is not possible at all . It will affect both sides. There is definitely not going to be any changes to this at all. No possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-11 09:22:04
