Date/Time: Tue, 26 Nov 2024 23:40:13 +0000
[User Discussion] - chart
View Count: 277
[2023-10-10 14:50:51] |
blakerowe - Posts: 1 |
i am new to sierra chart, i have a link to someone else's sierra chart setup that i want to add to mine that i can use. i cant figure out how or what to do with the file to make it show up on my screen.
Attachment Deleted. |
[2023-10-10 15:57:35] |
John - SC Support - Posts: 36309 |
Follow the instructions at the following link: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Although the instructions are for a chartbook provided by support, the main point is the same, which is to put the file in the 'Data' folder under your main Sierra Chart installation folder and then you can open it within Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
