Date/Time: Tue, 26 Nov 2024 22:13:35 +0000
Numbers bar layout, very clean and clear. Thoghts on how to replicate?
View Count: 276
[2023-10-10 14:12:35]
cgarrad - Posts: 27
Any thoughts on how this numbers bars was produced?
https://youtu.be/e4hTcxjE3ug?t=731
Regards.
[2023-10-10 15:50:21]
John - SC Support - Posts: 36309
It uses all 3 columns from the Numbers Bars study. The first column displays the delta (Bid/Ask Difference), the second column is the Total Volume, and the third just has the profile.
The documentation for the Numbers Bars is here:
Numbers Bars
[2023-10-11 20:27:16]
cgarrad - Posts: 27
I changed from 10 to 11 and back to 10 to try numbers bars.
I got this today on login. $173, inflation, is not that crazy!
[2023-10-11 20:28:05]
cgarrad - Posts: 27
File attached
imageScreenshot 2023-10-11 212344.png / V - Attached On 2023-10-11 20:27:43 UTC - Size: 61.43 KB - 68 views
[2023-10-11 21:00:00]
You have your package selection set to "Package 10 - Integrated Standard - 6 Months" which costs $172.80.
At some point when you were changing it, you must have selected the 6 month option by accident. You just need to change your selected package to what you want it to be when you renew.
Also, you are correct that you need to be on Package 11 in order to use the Numbers Bars study.
