Date/Time: Tue, 26 Nov 2024 22:35:30 +0000
permission denied
View Count: 375
[2023-10-10 11:56:24]
Vak412 - Posts: 4
hello,
i made a second account for sierra chart but when i want to connect to the data feed it gives me the permission denied ( i got my live credentials from amp futures )
i contacted amp futures and they said they enabled me and i need to contact you guys
Date Time Of Last Edit: 2023-10-10 13:38:41
[2023-10-10 15:42:16]
John - SC Support - Posts: 36309
We need to know the exact message you are getting.
Also, how are you setup? You may not need 2 Sierra Chart accounts, depending on what you are trying to do.
[2023-10-10 17:15:15]
Vak412 - Posts: 4
hey john
i want to use sierra chart for chart analysis and bookmap for execution only the problem is if i use bookmap and sierra chart on the same account it doesn't work because i can only login to one account so i asked amp support how i can solve that and they advised me to create an extra account and now i have for sierra chart a non data/ order routing only live account in combination with the denali data feed from your site but unfortunately i can't login
imagejohn sierra chart 1 .png / V - Attached On 2023-10-10 17:13:54 UTC - Size: 6.14 KB - 76 views
[2023-10-10 17:40:06]
Sierra_Chart Engineering - Posts: 17185
Regarding "permission denied", refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
Date Time Of Last Edit: 2023-10-10 17:40:27
[2023-10-11 12:22:35]
Vak412 - Posts: 4
i tried a diffrent server and then i got this message
imagejohn sierra chart 2.png / V - Attached On 2023-10-11 12:22:29 UTC - Size: 51.26 KB - 76 views
[2023-10-11 13:53:59]
Ok, we have no control over that. You need to ask Rithmic for help.
Date Time Of Last Edit: 2023-10-11 13:54:12
