Date/Time: Wed, 27 Nov 2024 02:27:01 +0000
Ver 1060 - Compact Tool Values Window
View Count: 996
[2014-07-18 11:45:36] |
NRGTrader - Posts: 351 |
The width of the Compact Tool Values Window is approximately twice the size of previous versions. Is there an option to adjust it's size?
[2014-07-18 14:34:36] |
User201106 - Posts: 62 |
I noted the same thing and prefer the smaller size as well. Please make this an option or revert back to the original.
[2014-07-18 14:41:08] |
There is some problem causing this which will be resolved.
[2014-07-18 15:11:10] |
Al SC Developer - Posts: 434 |
This will be resolved in ver 1161.
