Date/Time: Tue, 26 Nov 2024 22:12:07 +0000
Tradovate
View Count: 819
[2023-10-09 19:55:37] |
Utilisateur188232 - Posts: 22 |
Bonjour, j'aimerais trader le dax (eurex) avec tradovate. Est ce que je peux connecter tradovate sur sierra chart ?
[2023-10-10 14:31:44] |
John - SC Support - Posts: 36309 |
Hello, I would like to trade the dax (eurex) with tradovate. Can I connect tradovate to sierra chart?
Unfortunately Tradeovate does not allow support for Sierra Chart, so you can not use Sierra Chart with Tradeovate. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-11 07:12:16] |
Sierra_Chart Engineering - Posts: 17185 |
For trading EUREX you would use CQG: CQG Trading Platform Service Check what brokers work with CQG. And you will use the EUREX data through the Denali Exchange Data Feed: Denali Exchange Data Feed We can help you with the set up of the EUREX data. Your broker will help you with set up of CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
