Date/Time: Tue, 26 Nov 2024 23:30:26 +0000
AMP Futures (CQG Routing Only) -- Help Selecting Datafeed and SC Package
View Count: 258
[2023-10-09 19:05:17] |
mash - Posts: 10 |
Hello, It has been a while since using SC with AMP. I want know which datafeed I need for trading futures (mainly MES, ES, NQ, RTY) with sierra. I need TPO charts as well, so which SC package is best? Thank you! |
[2023-10-10 14:02:47] |
Sierra_Chart Engineering - Posts: 17187 |
You will need Service Package 11. We have temporarily activated this Service Package. So you are ready to go now. contact AMP and have them set you up on Teton order routing: Sierra Chart Teton Futures Order Routing: Setup Instructions This is the best and lowest-cost service. Much better than CQG and costs nothing. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing The contracts you mention are all index futures covered by the CME. So you will need to activate the CME exchange: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-10 21:48:39
