Date/Time: Tue, 26 Nov 2024 23:28:05 +0000
Set Number of Rows for Spreadsheet
View Count: 264
[2023-10-09 17:19:22] |
DaveTrader - Posts: 12 |
Where can I set the Number of Rows for the Spreadsheet study? (Screenshot, Link) The documentation does only mention that the days to load in the chart settings are not linked to the number of rows. But it does not mention where it is set then. Spreadsheet Study Inputs |
[2023-10-10 08:45:42] |
If anyone else is looking for this, I have found it in the study settings of the traidingspreadsheet under the tab 'Settings and Input'. (See Screenshot) Analysis>>Studies>>traidingspreadsheet>>Settings and Input |
screenshot-1.png / V - Attached On 2023-10-10 08:45:05 UTC - Size: 135.57 KB - 73 views |
[2023-10-10 13:31:32] |
Sierra_Chart Engineering - Posts: 17187 |
Yes: Spreadsheet Study Inputs: Number of Rows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
