Date/Time: Wed, 27 Nov 2024 00:30:36 +0000
Duplicating charts without linking
View Count: 250
[2023-10-09 13:30:29]
User416156 - Posts: 7
I want to copy a chart from one chartbook to another, but every time I do it using 'Duplicate Chart To Chartbook', it not only duplicates the chart in question in all my chartbooks, but they are also inextricably linked, so if I change one, all the other duplicates are changed. I only want one copy of the chart and I don't want it linked to the source chart that its copied from.
I have checked for linking, but under Link Number, link none is selected.
Please advise.
Thanks.
image2023-10-09 14_23_03-Sierra Chart 2491.png / V - Attached On 2023-10-09 13:28:36 UTC - Size: 154.76 KB - 69 views
[2023-10-09 14:34:50]
Sierra_Chart Engineering - Posts: 17187
A chart can only exist within one Chartbook. There is no other possibility. And using Duplicate Chart to Chartbook will only duplicate the chart to one particular Chartbook.
We think the problem is you have this option enabled for that chart:
Window, CB and CW Menus: Window Always Visible (Window)
Date Time Of Last Edit: 2023-10-09 14:35:00
