Date/Time: Tue, 26 Nov 2024 23:27:50 +0000
Two Symbols on Same Chart
View Count: 446
[2023-10-09 00:32:13] |
RockyTheRescue - Posts: 4 |
I would like to plot two symbols on the same chart - one in the upper half or "slice" of the chart and a different one in the bottom slice. I am trying to plot ES and VIX prices. Thanks.
[2023-10-09 14:49:19] |
Sierra_Chart Engineering - Posts: 17187 |
Yes this can be done. Refer to: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
