Date/Time: Tue, 26 Nov 2024 23:40:52 +0000
How can i get historical tick data for CME futures from 2000 on sc? not 2011
View Count: 235
[2023-10-08 23:55:28]
User395175 - Posts: 87
is there a way to get this data and use it in sc?
[2023-10-09 21:41:33]
John - SC Support - Posts: 36309
If you can get it, then you can load it into Sierra Chart. Refer the following:
Exporting and Importing Intraday Data Files: Import and Load
