Date/Time: Tue, 26 Nov 2024 22:23:36 +0000
Initial Balance
View Count: 273
[2023-10-07 14:45:35] |
Arcade1953 - Posts: 14 |
How do I limit the time the IB is displayed on the chart to end at 3pm CST. Currently, it prints on the chart from the start (8:30/9:30) through the overnight and stops at 8:30 the following session. Thanks |
[2023-10-09 21:18:52] |
John - SC Support - Posts: 36309 |
The easiest thing to do is to modify the code (if you can do some coding). This study is in Studies6.cpp in the ACS_Source file under your main Sierra Chart installation folder. refer to the following: How to Build an Advanced Custom Study from Source Code Another option would be to use the Color Bar Based on Alert Condition where the Alert Condition is true for the times you do NOT want to see the line, and then color it the same as the background. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-11 07:19:34] |
Sierra_Chart Engineering - Posts: 17185 |
Use this study instead: High/Low for Time Period - Extended And this supports a stop time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
